Hello
i dont find the Shadowbox under Subtools in 4R8 P1.Somebody can tell me it is to find?
First off, why are you using P1?
Please follow the instructions at http://www.zbrushcentral.com/showthread.php?208273-ZBrush-4R8-Update-2-Now-Available
- Make sure your object is in Edit Mode, and that it is a PolyMesh3D.
- Look in the Geometry pallet, ShadowBox is under Crease and above Clay Polish.
Do yourself a favor, stick with the version you are comfortable working in. Even if you are a version or so behind someone will usually try to help you.
