4R8 Extender Tool error (?) Take a look:
Trying to figure out why the extender tool is causing these newly split areas to be uneven like this. See how it dips down? Is there a way to avoid this?
Thanks!
Is that extrude?
Meaning the Extrude tool in the ZModeler brush?
That’s because the function you’re using in Extender is an inflation, which will bloat the geometry inward or outward, becoming more apparent on some geometry moreso than others, depending on where the vertices are. So not an error, as much as a limitation.
If you want a more uniform extrusion, it’s better to use more precise tools like ZModeler, or the legacy transpose extrusion functions.
