Hello!
The new way of drawing straight lines while holding shift makes certain types of workflows impossible.
Previously, drawing a line while holding down shift let you see in real time what type of mark the brush was creating, and allowed you to push in or pull out by tapping alt while drawing that line. You could also vary your pen pressure to change how thick/deep the mark was. This type of markmaking is a critical part of our detailing stage on high poly. The new version shows the guideline instead of the mark, is difficult to predict where the endpoint is, and doesn’t allow for pulling in and pushing out on the same line. It also means there is no way to vary the thickness/depth of the mark with pen pressure.
Is there a way to get back the way it was on 4r7?
Thank you
See you
Lucas
