Is there any way to change the matcap in the Tool and Subtool palettes back to good old fashioned Red Wax instead of this new-fangled White they gave us in 4r7 ?
Thanks!
Thanks!
Add to your StartupMacro.txt file this code.
code
[IPress,Material:CurrentMaterial]
[IPress,Material:MatCap Red Wax]
/end code
Thanks, but that’s not quite what I was looking for. That changes the mat cap for primitives and subtools. I want to change the mat caps over in the tray where all of the subtools are listed…
You’ll figure out how all of it works after a while.
I appreciate the help.
try this, a warning though it is always dangerous to mess with the zdata folder and usually advised against.
go to your install directory, zdata/materials/startup and rename skinshade4.zmt to something like skinshade8.zmt
restart zbrush if previously running.
