Hi, I’m using ZBrush R7 P3 with 3Ds Max 2016 and I’m unable to launch GoZ in 3Ds Max properly. As soon as I start 3Ds Max, it gives me an error right away. I use Windows 10. I tried to uninstall GoZ script files both from Max’s script folder and from macros folder in Users/Appdata etc, error disappeared after uninstalling and as soon as I install GoZ again, error appears. GoZ menu does not appear in 3Ds Max as well. So it’s clearly a GoZ bug.
Here is an error text I get from 3Ds Max script listener.
– Error occurred in anonymous codeblock; filename: C:\Program Files\Autodesk\3ds Max 2016\scripts\startup\Macro_GoZ.ms; position: 72707; line: 2170
– Frame:
– item2: undefined
– goz_action_item: undefined
– item1: <MixinInterface:menuItem>
– menuOK: undefined
– Error occurred during fileIn in “C:\Program Files\Autodesk\3ds Max 2016\scripts\startup\Macro_GoZ.ms”; line number: 2170
>> MAXScript Auto-load Script Error - C:\Program Files\Autodesk\3ds Max 2016\scripts\startup\Macro_GoZ.ms Exception:
– Unknown system exception <<
