Hello,
I am unable to export stl files correctly. After troubleshooting and nothing working, the only thing I could get to export properly in stl format was a zbrush default sphere.
I understand that there can be no errors to make a printable file, however even simple zbrush primitives I had worked on (with nothing complicated done to them) and decimated will not export properly. I am wondering if anyone has had similar problems, and if there is a tool in zbrush which can locate problem areas?
Thank you for your help,
mike
