3D Print Hub maximum size
I have a hollowed out sculpture to print at 79 inches. The reason I would like to work in the life size scale is to make sure my wall thickness is accurate. If i try to export using 3d Print Hub the maximum I can export is 50 Inches. Is there another function that will allow me to export over 50 inches using this plugin?
Are you using ZBrush or ZBrushCore? And which version?
Z brush full version 2018.
Thanks. The 2018 update included the ability to export larger models - up to 200 inches - using the 3DPrint Hub plugin. Your installation is clearly corrupt in some way. Did you install any plugins yourself or copy them over? You may need to download ZBrush again from My Licenses and do a clean install.
