3d print exporter_Limitation?
Hi
I am working on a large model that needs to be 198cm high.
Of course, it’s splitted in different subtools BUT, from bottom to top, this needs to be 198cm high.
I need to set up the file and export each piece at the good size, in STL format.
So I placed a cube into position and size, to fit my entire model so I can set the size for that cube and be sure my model will be at the right size in the end.
the only problem, is that, apparently, I can’t go higher than 50,8 cm.
Is there a way to go higher than that?
thanks.
Hi there
I run into same issue. Zbrush STLExported plugin has limitations in maximum size, true…
But you can always work in 10 times smaller sizes and then use any other free program to scale up 10 times your STL files. I use Netfabb for those final tweaks
Hope this helps
Yep thanks
This is usually what I do too.
Was just wondering if I was wrong somewhere or missing something.
:slight_smile:
