Hi
Graffiti modeled with 3ds max & Zbrush 4 (Goz), rendered with BPR, composition with photoshop. Hope you enjoy
Full Size = http://akze.files.wordpress.com/2011/10/akzefinal3.jpg
Hi
Probably the most original use of ZBrush I’ve every seen.
Really dig it!
~Corey
that is awesome
Can you post a breakdown of your 3D Graffiti? I’m curious to see what you did in 3DSMax and what in ZBrush
Nice one! Would love to see it in real life on a wall!
Corey & Eric = thanks guys
Milivoj = I wish i could, i wasn’t that good with spray :rolleyes:
Totyo = Basicly i did a low poly (about 4000 poly) with edited primitives on Max, then i tweaked a high poly version (about 5 millions poly) with “Move-Elastic” brush and the “deformation panel” (twist,taper,gravity etc…). I added some elements using shadow-box.
Then rendered with “BPR”.
Low poly = http://akze.files.wordpress.com/2011/10/low-poly1.jpg
High poly = http://akze.files.wordpress.com/2011/10/high-poly1.jpgPS Totyo = chui de Paname mais j’ai habite 14 ans entre le Bassin et BX
