Say you did your 3d copy function , and it went well. Now how do you save the texture that is now on your object and save it for use elswhere or even here at a later time?Thanks.
Texture>Save. Or save your tool with the texture wrapped onto it, then say yes when asked if you want to save the texture with the tool.
WoW! Thanks. To me your like some Z god.guess this applies to projection master to huh! Guess itll work if i save the object as .obj ok. thanks a million.
This is my last question. ok so i did what you said , and no problem. But, what if i want to have the texture in the document window so i can alter it/ i di a layer fill, but the texture look weird.Is there a selection of texture mapping buttons i overlloked before painting the model/ thanks and good day.
