2018.1 Corrupting files
I just spent many hours working on a design in the new 2018.1. Saved the file, and then went to open and the whole thing is corrupted. It says it opens the file in 4.1 seconds but the screen is blank and all it does is smear the square around the workspace. I never had this problem in the first 2018.
Is anyone else experiencing this ?
what file format did you save as? .ztl? .zpr?
Did you try checking the tool palate for your work? Sometimes tools will get added to the bottom of the tool list and you have to hunt for them.
Saved as as .zpr
Tried looking in the tool palette.
Nothing.
Feeling a little nervous about this 2018.1
hmm.
What is the file size of your .zpr?
If it’s a large file and/or has a lot of undo history in it, it can cause issues with loading sometimes.
Try turning on “Skip Loading” under Preferences > Undo History > . And then try opening the .zpr
Thanks Eric,
Tried that, still not opening. Guess that one is gone for good.
Will try to rebuild from an earlier save
