in all zbrush tutorial i saw it says in edit mode u get 1 circle and dot, but in mine i get 2 circle one big one small anbd a dot and the effect is seen only in the area covered by smaller circle i guess. in zscripts they set draw size to 64 and pull n push the diff parts of head and the whole thing moves as tho the brush is big enough, but in mine 64 size is so small that its like pinching the sphere from one side and adding horns to it. so ne solution or is this the way it works? or do i need to set brush size to 200+???
Change your Draw Size setting. It’s located on the top shelf, as well as in the Draw palette. The size of the inner circle is controlled by the Focal Shift slider.
