That would help , thank you. I have been playing around with Zsphere Tweaks but it seems to be acting as it should.
Let explain what you are seeing:
- zsphere model
- zsphere model with adaptive skin preview
- adaptive skin preview with x,y,z resolution tweaked only
- adaptive skin with xyz reso tweaked and mbr tweaked
It is when I am tweaking the mbr that the model does strange things and I can’t seem to get it back to the original state by changing the mbr. This is where I think the issue is. Just a guess, though.
neilford
It is a little difficult to tell what is caused by a possibly new adaptive skinning algorithm and what could be caused by the script. Generally the script seems to function like it should.
I noticed it is no longer possible to apply multiple changes to all unmasked zspheres. This could be why you had trouble resetting the Membrane Curvature. Until I figure out a solution remember to release the SHIFT key between each global change. For example, hold SHIFT and set the membrane curvature to 20, release SHIFT and then hold SHIFT and set the membrane curvature to 0.
As I am sure you are aware the Membrane Curvature (Mbr) under Tool > Adaptive Skin is a global setting whereas in ZSphere Tweaks it is applied to the selected ZSphere, unless of course you hold SHIFT.
Okay. Will do. Thanks.
neilford
