yeah mine is upsidown and all messed up, the buttons done line up. is there a new version in the works? possibly??
Sorry about the late reply.
Unfortunately between 1.55b and 2.0 Zbrush changed the way it reads .bmp files, resulting in an upside down image in 2.0.
This script is a bit out of date and a new version is in the works right now. Until then you can load Layout.bmp into ZBrush, flip it vertically and save again. PM me if that does not work.
TVeyes, just a belated thank you. I wish I would have seen this way back when. I kinda gave up on Pixolators script, and would love to see an update to your’s. Thanks in advance.
Dear TVeyes,no.
The idea to flip vertically the layout image of the script in question did not work.
I am sorry about that and hope you may find time to fix it so that Zbrush2 users can also enjoy your script.
:rolleyes:
Anatom
That sounds strange. Are you on a Mac or PC?
I am at work right now but I will post a new interface file tomorrow morning.
Anatom, flipping the texture vertically will work. Not sure what happened when you did it. Did you remember to export again afterwards. Remember the default texture export format is .psd, you should save as .bmp.
In any case here is a Layout.bmp that will work. Extract and overwrite the existing layout.bmp.
:lol: Oh, thanks so much, dear TVeyes.
I understood the problem:
I have used Zplugmaker before and, having changed the bmp layout, expected erraneously to see the change…
I ought to have deleated the old myplugin files first (showing the wrong desplay of the layout), then retry.
Now all functions swell and I can only express my deap facination at your plugin.
Presently Zbrush has advanced another step into animation and I can use
graspin soft to write an avi file which can easily be converted into gif and anything of the sort.
You are great!
Anatom.
TVeyes, i hope you don’t mind that i made a slight change in your script to help someone out with a problem. I don’t know much about scripting and could not get my own to work so i modified yours to suit their needs. if you want me to remove it let me know. here’s a link to that thread.
http://www.zbrushcentral.com/zbc/showthread.php?p=418265#post418265
edit: actually it still didn’t work how i wanted so i removed it, nice script though for when you want multiaxis rotation. thanks.
No problem SpaceBoy, send me a PM with what you were trying to change and I might be able to add it to a new version.
i tried to modifiy your sript to grab and export an alpha instead of using preview mode. mostly cause i cannot get the variable commands to work in my script to be able to save without the dialog window popping up and the filenames not copying over each other. my script is included in that page without the variables. i was just trying to help another user and am a novice zscripter. thanks again.
Hi.
Is there a version for zbrush3.1?
If there is, please help me to find it.
klesh,
There is already an option for creating a turntable animation in ZBrush 3.1.
See here:
http://www.zbrush.info/docs/index.php/Movie_Palette
