COOOOOOOOOOOLLL!!
Thats a good idea!
COOOOOOOOOOOLLL!!
Thats a good idea!
Hi.
Cool script. I have no trouble finding it and launching it and using it. However, I am unable to set it up so that ZLauncher automatically manifests on Startup. I have carefully renamed the file and placed it in the root directory but I don’t see the ZLauncher icon in the ZScripts pulldown. Like I say, it doesn’t really matter because I can find it and launch it - but it would be nice to have the auto-launch on startup. There is a previous file in the root directory called ‘defaultzscript.zsc’. Should I delete this? Thoughts?
Thanks!
~S.~
great script, but i cant execute it at startup. i’ve pasted the 2 files into my zscripts folder and renamed the “AutoZLauncherRevA.txt” to “DefaultZScript.txt”. but still the normal defaultzscript is executed.
i also have a problem using the zlauncher with the colorPalette script, because they both get loaded into the bottom space(->zlauncher disappears). is there a way to move the zlauncher? that way i could also just create a custom UI and put the zlauncher in there (so it would load at startup).
greets prowler
prowler,
This script was written for early versions of ZBrush. You can’t make it run at startup with ZBrush 3.1. Also, it will only display in the ZScript Window and, as only one zscript can be active at a time, will disappear if you load another.
