To assign a hotkey or a new hotkey just [ctrl]-click on any button, menu or brush, then assign it a keystroke…
thanks dewdle!
As the title says, thanks a lot jblazer, you totally da man, been trying out the script and have to say its the best thing since sliced bread, nope, its even better :D:D:D
no more zBrush sliders for me wooooohooooo
Hey, JBlazer, this is what I’ve been looking for! But I have a small problem with the script. The Z Intensity and RGB buttons seem to do the same thing? I tried assigning different hotkeys to all of the buttons, but the RGB and Z Intensity sliders are just tied together, they go up and down simultaneously. This isn’t actually a huge problem, but it’s still a little wierd. Anyway, thanks for sharing this great script!
Oh, never mind. It stopped happening after I initialized Zbrush.
Hi guys
Who teach me about to instaler the plugin?
I don’t understand very much English.
I want to know how active “brush size” and more fuctions with my Touch Ring
2 hours and still nothing
Wacom-up-down.zsc is in zplug folder (thanks to Jblazer!)
I assign hotkeys
I config the touch ring of my wacom intuos 4 wireless
Result:
On my wacom tablet only the first point light is lighting even when I clic on the center button of the touch ring … but obviously when I clci on this button I go through the four config (brush size, Z intensity, RGB intensity, Focal size).
On Zbrush the brush size it works but not really fluent. the Z intensity crease and decrease only around 10 (-9 and -16!) … don’t know why. RGB intensity and focal size Don’t work at all…
I’m really surprise that Zbrush or Wacom never did something to clear this problem and give to customer something that work!
Why didn’t they give us some preset for zbrush, photoshop, maya,… The wacom tablet is a so powerfull stuff, and expensive…
[HR][/HR]Hello. First post here.
Just picked up an Intuos4. I can adjust the brush size just fine with the touch ring, but cannot zoom or rotate the canvas. I can, however, zoom in both Sculptris and Photoshop, so it’s definitely a ZBrush compatibility issue.
Can someone possibly help me?
Hello. I have been using an intuos 4 with zbrush 4R2 for awhile now with no problems. I was able to change brush sizes using the default brush size button on the touch ring. After going to 4R2b, it no longer works. It still shows the [ & ] in the keystrokes for brush size, but it stopped working. Can anyone give me a hand with this? Thanks very much!
-Matt
I am lost I have no idea what a macro is and no idea on how to write computer code like Objective-C, C++ or any other such coding one would have to know to fix this problem. The problem is simple on an Intuos 4 I would like to get the touch ring to work making the size of my brush larger or smaller. Hot key don’t seem to do the trick under Zplugin>Misc Utilities <<Brush>> something is getting lost between the Wacom Tablet in System Preferences (MAC) and Zbrush. What I am getting is a flickering like it wants to work but can’t. “Am I losing my mind or is this a bug” would be my first question? Do any of you find a way to get this to work and if so could you please explain in simple english how you did it?
Grrrrrrrrrr!!!
I am having exactly the same problem as Tatge. Strange thing for me is that I had the problem with 4R2, but then one day it went away. The problem is now back since going to 4R2b. It is very frustrating because I am now so used to using the ring to adjust size.
Hey Tatge… I got mine working just now based on input from another thread. All I did was re-assign the [ & ] keys to draw size by “customizing” them. If you don’t know how, this is Marcus_ Civis’ post on the other thread:
You can find the Brush size buttons, labelled <<Brush and Brush>> in the ZPlugin>Misc Utilities menu. Ctrl+Alt+click on a button and then press the relevant hotkey (e.g. [ for <<Brush). Repeat for the other button, then press Preferences>Hotkeys>Store to make sure the hotkeys will be available each time you start ZBrush.
I don’t understand why it work seeing as the [ and the ] were the default hot keys, but re-assigning them worked for me. Good luck. Let us know if it works for you.
That is what I did and to date I have had no luck. What I get is a
flickering of the brush and once in a wile I do see a change in size.
Are you running Lion on Mac? This is why I am thinking it it’s a bug.
Also I now have a problem with Zbrush crashing at start-up bad script error can’t open from the dock
Mark
Sorry that didn’t work for you, Mark. I am actually using Snow Leopard 10.6.8. I haven’t updated either of my macs to lion just for fear of this sort of thing. I had a lot of trouble with some programs and peripherals when i went to Snow leopard, so I decided to wait for Lion. Wish i could help… sorry about that. I’ll keep my eyes open for any fix for you.
I also have problems using the touch ring of my intous 4 . I did everything wich was mentioned here in this thread (placing script setting hotkeys -> n´making settings in the tablett witch [ and ] but nothing happend in Zbrush. I am using Zbrush 4r2b and OSX Lion ! Any suggestions …strange i bought this tablet exactly for those kind of settings and they didnt work…that sucks
It is a bit of a coordination thing but do it just like this:
1 With the intros 4 hooked up and Zbrush running click the center button on the touch ring until you see the on screen menu show brushes.
2 On the top menu bar of ZBrush go to the zplugins>Misc Utilities. You will see the <<Brush button (small) and the Brush>>
for (large)
3 This is the tricky part that must be done in order…hold down the Control & Option keys with your right hand, with your left hand use the Intous pen to how click and hold the <<Brush button down, with your left hand holding the pen still in place release the Control & Option Keys and press the number 1. This saves the hot key to make the brush smaller.
4 Once you have that repeat steps 3 again but this time with the large Brush>> button and use the number 2.
5 Be sure to save under Preferences>HotKeys >Save click ok.
H Tatge
I found out what was happening !! Strange things ! I assign [ and ] as shortcut to the brush size. Then i did this for the touch ring in the wacom settings…back to ZB i tried it. Nothing happen ! So i looked bck and forth. Then i hoover over the buttons for increasing/decreasind the brush size in ZB again. Suddenly the tooltip for decreasing shows ALT + F12 (???) and for increasing ]
I assign again AKT + 5 (Mac keyboard/ OSX Lion) and again tooltip in ZB shows ALT + F12 !! So i assiged other short cuts and voila´ it works. Maybe thats a bug/glitch in ZB ? And maybe thats why some peeps have the same problem like me. Does it make sense to submit that to Pixologic ? And how can i contact them ?
2Step
