I have the same problem, Ive tried page compatibility and a few other things that dont work. is this a IE problem.
I just checked on a couple systems. With IE 8.0.6 the page looks like as shown in your screen shot. My other computer has IE 8.0.7 and the page loads correctly.
Which version of IE are you using? (The full version number that you get by clicking on About Internet Explorer)
Try updating to the most current version of Internet Explorer. Also try simply using something like Chrome.
Thanks mine is 8.0.6XXXXXXXX I’ll update to 7 and try that thanks for the quick reply. Mike.
edit: I updated and I have a newer version of 8.0.6. Version 8.0.7 maybe for Win 7 I’m still running XP. I’d like to avoid installing another app that I wont use just to download a plugin if I can albeit one of the best plugins ever.
I had the same problem. Page properties/ encoding/ read page right to left (this is what I did in IE 7). Anyway heres the ZIP of ZAPPLINK 4 from the Pixologic download centre. Enjoy.
That worked for me, thankyou for your help Soulty666.
Quick question is there a way when saving a multiview to have BPR on?
BIG!!!thank :D;)
small_orange_diamond
THANK YOU Pixologic
Mac OSX build
Will this work with “GIMP”? Hope this does’nt sound too dumb.I usually just export my doc. via .psd to gimp manually.
dlb: yes, it works with GIMP
Plakkie: please, can you open a ticket at the support?
Thankyou, its a very welcome pluging, cant wait to try it.
Thanks…It’s working perfect for me!
YAAAAAAY
thx
great plugin - just what i needed.
Has anybody had success using Zapplink with GIMP?
Using Zapplink on a PC (Z4) works just fine with PShop CS3.
A pleasurable workflow experience if ever there was one.
But attempting to use it on OSX 10.6.4 with Gimp2.6 (Z4, imac i7) is a most useless exercise in futility.
First, your lucky to connect to Gimp at all after selecting the Zapplink button.
Z may just crash outright, it may bring up the window to Set Target App.
50 percent of the time, Z will crash when you select Gimp as a new target app, or select OK.
If you are able to get it open in Gimp, and you edit Layer1, and then save the file, it will not change the dialog window in Zbrush. Your buttons will remain “OK Unchanged” and “Return to external editor”…as if you did not save an edited file. (this happens every time)
If you select OK Unchanged, you throw your work away.
If you select Return To External Editor, GIMP will open another image…this image is a copy of your edited file that you just saved. When this file opens, the Zapplink Dialog window changes to what it should have been the last time you saved,…with the button “Re-enter Zbrush”. You dont have to Save again, you can just select Re-Enter.
Select Re-enter and you get the Zapplink Projection window with PICKUP NOW…or you crash.
So I’m wondering if there is a different workflow for GIMP?
As Gimp works differently than Pshop, is there anything I need to do to the file in Gimp before saving?
Are you sure that you deinstall correctly the public beta of ZAppLink 4 before installing the last version?
if you need a cheap Photoshop stand-in for ZApplink on the Mac, Pixelmator works.
Totyo-
ZApplink.zsc Aug9 2010
ZappLinkData_4.0 (all files in the folder dated Aug 9 '10)
cgbeige-
I’ll checkit out, thanx
