Five minute drawing…
Thank you Southern
cameyo
Thank you Southern
cameyo
This is for the people that don’t have a “BRUSH”
Hi Petsagouris
Welcome aboard!
Akira motor bike inspiration?
And have happy Zbrushing!
Pilou
I finally got my copy of ZBrush today so I HAD to do something with it even though I only had enough time to install it and play around with it for a few minutes. I thought I would try out the ZSketcher script because it looked great…and it is! It’s like working with real pencils. I’m ashamed my very first ZBrush creation isn’t more awe-inspiring, but oh well!
Really good script!! I was just testing it…
Yo Lanito,
very, very nice drawing and wright on time to illustrate a problem/challenge I’m trying to figure out:
What would the best and/or fastest way be (in Zbrush!) to create a cityscape like in this drawing?
I mean, with the same perspective, point of view, details, etc…?
Anybody any suggestions, tut,…?
Maybe make a new post about this issue?
ola, Fets!
off topic but since you asked - i think the fastest way to do cityscapes is creating an alpha with alpha 00 and spraystroke and applying it the alpha century way to a hires 3dplane or terrain tool like i did in the below ones with the exception of the upper right one which was done by placing a sphere and dragrectangling up cubes on it one by one with draw perspective on.
the spraystroke - alphacentury technique doesnt allow for details, but of course you could carefully build up an alpha manually by placing cube above cube in gyro-mode, rotating them into place along streets and suchlikes and do the alpha century afterwards to be able to rotate all of the terrain at once. :ex: rotating cubes often ends up in severe jaggies, try to overcome that by using hires ones, roadmap-stencils, huge canvases, AA, depth cue etc.
addendum to spraystroke: i believe its best to reduce flow + maximize placement to avoid “heaps”.
for details: of course its possible to add some on the quickly done alphacentury ones but there are mucho better possibilities: i dont have the time right now but you might want to do a search for some useful tips on creating houses/cities by Pusghetty and WingedOne (who has done a random box script which should work great to build cityscapes). also check out Marcels gallery - he has done a few excellent and detailed cities!
hope this helps to get you started
Juandel my man,
you’re ZZZZuper.
I’m gonna dig in to this as soon as my “Bald Eagle-project” is finished. Many many thx for the effort.
If the deadline, for the project I need it for, promits me to do it by using Z, I will show you the outcome in this or a new post.
Once again: MANY THX!
and exact script, that is almost the same as Alias Sketchbook…wow…
Now my tablet is getting some real use!
Thanks!!!
For who-ever is interested, I posted a wip starting from Zketcher too. You can find it here
I think I made it subconsciously inspired by Davey_1’s contribution. Zketcher rocks!
My Comic-Hero Dark Hunter …
Made with Pencilcase. Sometimes i altered the settings a bit but most of the time i used the presets.
http://www.zbrushcentral.com/zbc/attachment.php?attachmentid=3492&stc=1
Too Good Le Discot:)
This is outstanding for too many reason to mention! But since you are so displeased with zbrush
, maybe if you record a zscript of the process you take to make such a stunning work , the whole forums praises and thanks might cheer you up?
thanks for sharing your work!
great script ,thank you very much ,works like charm.
Thanks very much Le Discot:)
Kircho
My god… will Zbrush functionality ever cease? Its constantly expanding through things like this and the other updates… I’m shocked everytime I load up the forum nowadays.
I need a tablet so bad now… when modeling you can fool yourself with a mouse for a while… (I’ve been doing it for what? 2 years now? maybe longer) but when you get some functionality with a pencil built in a mouse just doesn’t cut it.
I predict some day that Zbrush will make its own tablet… hehe then you’d have so much form and functionality built in…
hi all
and script
THANKS Glen
this was done with standard z brush tool
i will have to investigate this zsketcher.
