SUPER! Klasse! Applaus!
small_orange_diamond
LemonNado
LemonNado
Ok, I’m confused about how that works.
After he inflates the lower portion of the leg how does he go about putting the circle on the top of the leg? I don’t see multi marker hit, and I don’t really know how go pick the script apart to figure out what’s going on with it either. In fact, all I can discern is a large dot appearring on the leg as if by magic.
Thanks
Hi billrobertson42.
I can explain this to you as I had the same problem until I finally figured it out. Just before the “large dot” appears on the leg he hits the Projection Master button (U cant see it on the script). In projection master make sure u have the following selected…
2.When in Projection master select the SINGLE LAYER BRUSH. Select Alpha BRUSH 48. Select the DragRect Stroke. (Feel free to change these options after youget the hang of it)
Also make sure you are in EDIT > Draw and Zadd is on.
Now drag a circle on the leg(or whatever 3D object you have on the screen). You will see the dot appear and you are then able to “move” “scale” the dot into position. Once you are happy with it just hit Projection Master again and you will see that the dot has made a large BUMP on your 3D object. EASY!
One last thing…you have to make sure you turn your 3D object into a Poly Mesh. You can find the “Make Poly Mesh” button in your TOOL menu. Also it helpsif youhave a large poly count depending on how much detail you are going to add in Projection master. More detail added means you need more polys to deal with it.
Hope this helps you like it helped me.
Cheers.
p.s. Any questions feel free to post or send me a message. Im by no means a expert at Z-Brush and im still learning but I will help if I can.
p.p.s If any of this is wrong feel free to correct me. Im looking at the Z-Brush masters lurking around when I type this.
That does help. Thanks.
How can we see that ?
In the “text” file what is the code to call Projection Master?
Seems not to appear
i can just see “Freeze” is that ?
Idem on seeing the script even slowly, how can we see that projection is called ?
you can’t. I recall Aurick answering a post somewhere on similar thing and saying it doesn’t show up in the zscript.
anyone making a script that uses pm could add a comment right before and right after tho stating …about to go into pm …left pm or whatever tho so people would know what is happening.
Like this robot more so that its done purly in zbrush. Iv always wondered how you make the tubes as a seperate object yet they fit perfect into place can somone explain how this is done, this also applies to other parts how they scale up and fit so well, it almost seems imposible without 4 port views.
multi malker tool or multi marker plugin
Hi BigMike !!
Can you aswer one ( maybe two ) question ???
HOW did you put all pieces together ???
thanks and very good work man
seeya
hi again …
markers solve my problem !
Very cool. Thanks for the zscript too.
r
