WO sketchbook.
small up
skin and scales test
nice job so far.keep it up.:wink:
Thx a lot Diablo :slight_smile:
Small udapte
looks good :slight_smile:
I think the neck could be a bit thicker though imho
Thank you Fynn for your return:) I corrected, and Ithickened the neck.
I make you shared a test of skin that I carved withthe damstandard, deco and standard brush
Hello friends!
I worked over again the lower jaw, and the scales.I also worked over again the skin, and addeddetails on the scales with damstandard and thebrush noise.
I hope u like it
hello everyone!
I finished the bust of dragon soon.
I must correct things like the teeth.
Small adjustment also on the level of scales, as well as correction also on folds of skin.
I hope that will like to you, I forwards to you whilewaiting for that I finish a rather simple test of rendering.
Sorry for my english
Hello friends!
I finally finished my bust of dragon.
I forward to you some render which has was made under Vray and composite under photoshop.
I hope U like it :slight_smile:
My art station :https://www.artstation.com/artist/willow
hey really cool stuff :wink:
thx a lot Atomizzer!
I forward to you different the brush that I used, as well as the steps from returned for the compositing.
That dragon turned out great. Thanks for sharing the process shots.
Amazing man! Thank you for sharing the process :slight_smile:
Thank you friends,
it is a pleasure of sharing the process, I would try to do that on all the sculpt:D
Hello friends!
I begin new a sculpt, and I go tried to make a face.
I make you shared the block out , and still thank you for your returns on the dragon
hello friends! I forward to you the continuation of my wip
Hey! Nice start! you can check out my online zbrush course if you would like to learn it to a deeper level, check my thread here:
www.pierrebenjamin.com/online-workshop/
https://www.facebook.com/artofpierrebenjamin
http://www.zbrushcentral.com/showthr…=1#post1143224
Good evening friends!
I forward to you a wip.
Do not hesitate to give me your opinions andadvices
I really like your head studies.Keep going.btw stunning job on your dragon. :wink:
Hi guy’s!
I share you a project that I make over my free time.
It is an “Egyptian” room Which contains an artifact which floats in the middle of it.
I work for the moment on the cylindrical wall, which makes it tower of the part.
I share you the out block of the room, like one returned that a small portion of the wall.
I hope U like it!
C&C are Welcome
Hi friends!
I continue carved wall, it is long very long.
Its refined technique of sculpt allows me, and to retain the way of carved.
C&C are Welcome.
