good concept. great modeling and topolgy.
WOO, awesome diffuse map
[color=yellow]Hey All! Thank for comments! New update Render test XSI Displacement - model 16.000 poly, displacement map is taken from model 1.800.000 poly
hmm…
i would twick that some more.
getting the correct effect for disp is allways hard.
[color=orange]Hey All! I would like to present variants texturing a tree, which will
be used in final stage XSI.
[color=blue]I want to notice model of a tree only 400 poly:lol: :lol: .
Friends! I would like to introduce to you result of the test of animation of my animal. I wanted to check up an opportunity of adjustment of a skeleton and binding to model. As far as it will be correct to look. Here you can download it [color=cyan]High Res and Low Res video file.
Except for it, I check variant as it will look at movement of model with a displacement map, bump a color map. I want to make movements by relatives to real. But test variants of color animation I shall present later.
Very nice! And I see you use the best program for that 8-).
One crit only… towards the end, when he’s moving his mouth, then the rest of the body is frozen. Always move the body. Even if you move it slightly back and forth and siedeways. Just a little bit, it has a major reality impact. Try to mimic the speed of his breath while standing still. Even if you do not animate the volume, the rhythm will be perceived as breath.
Looking forward to more!
Lemo
Many thanks =lemonnado=. Very good remarks concerning animation. I shall work even above realistic movements and I shall try to achieve more the best results.
[color=yellow]All greetings!!! I continue to spread fruits of my creativity. I for a long time was not, but actually I was not idle. I tested animation and made
low poly model of the human which it is possible to use as the base form.
This model I shall lay out later.
I shall be glad to hear your comments
nice work!. i like the tree
Next render test in XSI. Shader include 3d_snow.
Coming along real nice!!! Now, plop some vegetation into that scene, let the animation render. I’m ready with popcorn and a remote!
Cheers
Lemo
Like to see what it looks like when it’s done…
Looks like a sabertooth, a hippo, and an elephant mix.
Thank Lemo, concerning vegetation - I have already prepared a stage with trees and leaves, I shall lay out later. I offer to take popcorn and beer :))))
Next render test: Agrono in deep forest
Hey All !!! I have a little modified the image inPhotoshopa picture, I wait for your comments :rolleyes: :rolleyes:
Hey Man its looking good
Only thing which is catching my eyes is that the creature looks like its made of stone, its skin or expression is too rigid…
very cool, but i think you should work on the texture for the tusks
I think you should work on the teeth and the eyes. Make him more menacing. He kinda resembles Barney The Dinosaur.
