Does anyone have a link to the zscripts and files for texture master that will work with 2.0
When I click the link above to get the zip it won’t give it to me.
Thanks
Thanks
the texture master doesnt do the same thing as the projection master, Id use that instead of the texture master.
First: place 3d tool on canvas, check.
Second: enter edit mode, check.
Third: exit edit mode, check.
Next(and last): press G or drop button
Message: “3d mesh first must be created from zsphere tool. Press one of those buttons and try again” An arrow pointing to unified skit modifier. Make Unified skin drop it on canvas, the same message again.
Try and try and try… Good luck!
the link to Texturemaster is dead
… tell me if it is because of there is a newer version or another link
When I Try to get Texturemaster I’m moved to ZBrush and I love this program but buying it again won’t help. What can I do?
Judith
Hi Judith,
If you’ve purchased ZBrush then you need to upgrade to version 2. Projection Master is built into it and includes all the features from TextureMaster, as well as new features to paint displacements.
The only people who should be using TextureMaster anymore are demo users.
The Downloads section at www.ZBrush.com includes links for Mac or PC users to upgrade to ZBrush 2 for free.
