I already knew most of this since I’ve been texturing in Zbrush for a few years now, but thank you very much all the same. I’m a tutorial junkie and this is done very well.
thanks man
very useful tutorial. it makes the process much easier to understand for a beginner like me. i look forward to seeing more from you.
You should charge money for this!
Is it me or is the link dead? thanks I press on the download link but there’s nothing there.
First I like to thank everyone for their comments and support, realy appreciate it.
Regarding the link it would apear that Mediafire is down. I will check again in a hour, and if the link still dont work im going to move all my files to a more reliable service.
Any recomendations for file hoasting service would be thankfull.
Hello everyone and hello TEZ =),
Simply speaking, thank you for that. Tutorials like this one are brilliant for me. I am total beginner and ZBrush does not seem to be easy for me. However, things become much easier when someone shows “how to do that” and I hope you will have time to make more tutorials =). I found this one very good, clear and understandable.
Thanks
I’m using the new Zbrush and am having problems simply applying an image texture on a surface. I have the fast shader applied and my image loaded up above it, but I only see the Fast Shader. Is there a viewing texture button I need to press or did I do something wrong. If anyone could help. Thanks
You have loaded the texture in the correct place, but you need to 1: have the correct subtool sellected, and 2: select the texture from the right texture menu as shown in picture below.
You also helped me on YouTube email, so I want to thank you 2xs here! Excellent tutorials! Oh and I just clicked on the download link of your first post and got an error message unzipping. Maybe its just me, would you mind reuploading or sending it to me?
Hello. I have just download it, and extracted the movie fine, so it must be getting corrupt during your download. You may want to try again.
Awesome ! Thanks a load, you make it all so easy !
Great tutorial Tez. I was kind of hoping when you started talking about UVs that you would show how to import UVs that have been done in maya or another program thou.
That could be arranged in a video. I like to keep to a single topic as to not over load infomation in a single video like this.
Thanks to eveyrone that has commented.
Iv done a UV pipline video tutorial for Zbrush, on how to work between external applications with Uvmapping. Im making a new dedicated thread in which il post the link here also.
That’s awesome to hear Tez, importing UVs to zbrush is something I’ve always had troubles with and is also the cause of holding up the project I’m currently working on right now. I look forward to that link good sir
