thanks way cool
Congratulations for the great work!
Barzo Dobre!
Beautiful Beautiful Beautiful work
I saw the thumb of this around the weekend and it looked fantastic but I didn’t have time to look at the thread. Truelly worthy of the top row status.
Congratulations
:D
Amazing work…
small_orange_diamond
Wow, Excellent! I think that you are great 3D artist.
Great piece man! Great modeling and render! Thanks for sharing it
Hi.
Thanks for the comments. I wasn’t replying for some time because I wanted to wait for all the questions so I can make a bigger info post. So here are things people were asking about on various forums:
Some technical info.
Zbrush model is around 8 milion poligons or something like that. Textures are from 2k to 4k depending on the object. Face is 4k.
Scene is rendered with 2 area lights (raytraced of course) without transparency for speed purposes + 5 lights with 1k deep shadowmaps. Ambient occlusion was rendered seperately as a pass. Face has raytraced reflection so do the eyes. Whole thing is done with displacements, even toothpick :). Clothes have fractal procedural as displacement on top of the zbrush one and thats what is giving them the rough and almost hairy look of the hat and adds quite alot of poligons in the process. But hey, thats the main strength of renderman so of course I will slap displacement on everything I can. Don’t know the final count of poligons for rendering but it will be quite alot because of that fractal. 10 milion at least. Also 100k hair in the scene.
There is depth of field and serious antialiasing 8x8 samples, 8 width, Sinc.
Shading rate 0,25 (renderman thing), so 4x4 shading samples (I think, math is hard), hence the sharpness of the displacements and thats why hat has the peachfuzz effect .
Beauty render took 30 minutes, and so did raytraced AO pass (don’t remeber how many samples I used). Rendered in 3delight2 for Xsi… my bad, Softimaaaageeeee. Xsi 7.01
Materials. For face its miss_fastskin material with skin2 preset in 3delight property. Everything else has architectural material (because of the oren-nayar) or cook-torrance (because of the architectural bugs
All clothes including hat are architectural with oren-nayar. The furry look of hat is the fractal procedural in displacement slot + some falloff effect,fresnel.incidence in xsi or whatever your application calls that. -
Skin details on a sculpt were mix of manual work and some sand/marble alphas. Thats how I always do it. I prefer to do lips for example with std brush rather than trying to find properly lit alpha. Ill do it manually faster. Out of curiosity I tried doing it the inflat way from photoes, but it sucked so I did it my way.
Pores are just several layers of various sands/concrete textures + some manual tweaking after. Like for example slight rows above his lips and such. Also I used some spray brush I think for some of them.
I am unable to tell you how long it took. It was testing and learning piece. So I tried various aproaches for the skin. First in mental fail with even such desperate acts as using physical SSS (which btw is broken) or normal mapping (also broken). When it finally stopped rendering I switched to 3delight, had to learn from scratch but at least it finished render. It was redone quite few times so I lost count. This was the first time I used compositing, hair etc. So alot of learning here.
There was some color correction and grain added in compositing.
-Stary piernik literally meams “old gingerbread”, but it is a expression that means “old fart”.
Piotr
Your best work until now !!! Congratulation !!!
hey can u please suggest me any tutorial for displacement map…
I have done RENDERING ZBRUSH DISPLACEMENT MAPS using multi space3 and rendering with maya+ mental ray… instructor scott spencer…a gnomonology tutorial …but i dont good result…i am using maya 2008…
How to render Displacement maps in maya
open your technique~!
be eager to know
wow…awesome…nice sculpt…rendering…great …
very nice! i feel like the pores on the face are a little too uniform however. particularly in the nose.
Aż fajnie się czyta jak Polak na międzynarodowym forum pozamiata:)
That man looks totally real. Great sculpt and stunning displacement.
Is that light a specular or you have added the second light?
Wow.wonderful detail and nice rendering
No comment
Wonderful …
Your Art with ZBrush … Bravo
Perfect ! good Model and nice renderring
Fantastic. That guy looks absolutely fed up! Love the moustache, amazing textures and lighting too. More please!
Very nice,… the eyes are perfect. Great art.
