Right, it looks like a fresnel overlay shader. However, what is the LSkin07 that looks to be in the txtr00 channel?
Great work, your zbrush render is awesome. any tips?
i can’t seem to get a hang of rendering in zbrush, my 1st few renders i ever did look like wax or something.
EDIT-
i saw your post on the SSS in the earlier post so thanks for those, after soending about 3 hours trying to make something of it and see what i could do, i ended up deciding that it’s not my materials/render but i just need to go a bit more in depth with polypainting to get my sculpt/render more like this one.
sculpting details is easy enough for me but painting them to look realistic is a whole new story.
Super !
Good job. Some tips for skin shader?
Superb sculpt and render -> thanks for sharing the render breakdown and sss shader setup
small_orange_diamond
:d:d:d:d:d:d
Hey PSTCHOART, could you tell me what the LSkin07 is in the texture channel of the S2 Fresnel material? Is it a skin shader you made and if so, how do you assign it to the texture channel like that? I’m also curious as to how you control the specular highlights on the skin so it isn’t so evenly distributed?
Thanks!
Awesome work …
impressive work!!
Awesome work
as always.
skdzines Hey PSTCHOART, could you tell me what the LSkin07 is in the texture channel of the S2 Fresnel material? Is it a skin shader you made and if so, how do you assign it to the texture channel like that? I’m also curious as to how you control the specular highlights on the skin so it isn’t so evenly distributed?
Thanks!
The Lskin07 shader you are inquiring about is on of Lucky_1’s. You can find it here - http://www.zbrushcentral.com/showthread.php?46175&p=490687&viewfull=1#post490687...Scroll down to about the middle of the page and you will see the zip called Luckies_Mats.zip
Very good, perfect skin, this man wanted to know how to make this delicacy. What techniques were used?
What are your settings for the sss and ao?
