problems with high freq details in Proj Master
Hello all,
I am tryingt o apply some high frequency details from an alpha map I created from Elephant skin. I am at Subdivision level 5 and I apply the alpha with a simplebrush in the projection master. It looks good. I pik up the object and wham, the texture disentigrates into a lumpy mess loosing all the details. It seems to be closer to what I want when I use it as a mask so I know the object’s geometry can handle the resolution of the detail in the map.
Any ideas what I am doing wrong? i have tried using bump brush and simple brush as well.
Scott
You can try playing with intensity levels. If your alpha is mostly middle gray you might have some troubles…there is a max button in the alpha menu that might help…also use the button next to it to set the radial falloff to somewhere in between 10-15. That should give you a better alpha to work with…allowing you to set some higher intensities without outline problems.
at level 5 how dense is your mesh? obviously the denser the better for those fine details. I do the above…I also make sure material is off…I use rgb only with no color or textures and play with intensity levels til I get my desired results. don’t forget to write your settings down for future reference…it makes a big time difference for the next model!
well theres a few ideas for ya to try…hope one of them helps!
