Pixologic Release: TransPose Master (PC & Mac)
Yeah, it ate one of my subtools as well. :confused:
I guess I’ll just go back to doing it by hand. 3.5 REALLY needs to find a way to put the nail in the coffin of this kind of feature.
It would be nice if we could transpose a tool, and then easily repeat it for each subtool.
When I try and load a previously saved TPose mesh, it crashes after like 5 minutes of trying to load it. One obvious problem is when I saved the mesh, it seems some of the normals were reversed when I first created it.
EDIT
Ok, I fixed the flipped normals issue, recreated the TPose mesh yet again. And yet again it seems to hang for like 5 minutes. If it does change the ā€˜master’ mesh, it seems to clobber subtools as well.
I hope when 3.5 hits, there is a bulletproof solution to our posing needs, because I am just going back and doing it by hand.
Thanks for your sharing. Thanks for sharing this useful information. It’s great.
Hi!
Could it be that there is a problem with transpose-Master ans ZBrush 3.5r2?
I try to transpose the DemoSoldier but it works not correctly!
Transpose Master for ZBrush 3.5 has not been released yet. You should not install the version for 3.1 as you will have problems. This goes for all plugins. Please wait until the updated versions are released.
any ETA? I count on many of the official plugins for work. are there any that are now built into 3.5?
You have to wonder why they werent just built into zbrush 3.5
@kravit, because then zbrush would have to be updated for every little change. plugins are way easier to update and modify and seem to get changed more on user feedback in a more timely manner.
secondly, nearly all plugins are just scripting routines of functions already in zbrush, nearly everything this plugin does can be done manually, it just takes longer.
I did some tests with TransposeMaster because I still have strange errors.
The first row (see the jpg), I transposed a head. After the calculation it was real small and deformed. Maybe an UV problem, so I deleted the uv’s. Same problem.
Then I imported the object made by Headus-UVL to be sure it has bothing to do with C4D. As you see there is no difference.
I exported the model as an .obj (with uv’s) from ZBrush, an imported it again, no deformations and surprises.
The last row shows the undo of the transpose…
BTW, the deformation in the first row is stronger because of the higher subd and sculpting.
Exporting and re-importing the model yesterday, was a miracle that did not deform the model. Today I tried again but it did not work :confused:
There is no problem to pose the model when it’s merged. When it is splitted again the UV’s are ok as you can see. :mad:
So where is the problem?
If they were, you clearly wouldn’t have 3.5 right now since they’re still trying to get the plug-ins updated. My guess is they knew they wouldn’t be able to release 4 on time so they had to throw people a bone to keep them at bay. 3.5 is that bone, even if it isn’t perfect.
What’s more curious to me is that they have people beta testing this software long before it gets in the hands of the community. Why aren’t those beta testers bringing up all of the concerns that I’ve seen people complaining about for the last couple months? And if they are bringing them up, then why aren’t those things being resolved before release? Those are, of course, rhetorical questions; I don’t expect an answer.
In lieu of eternal free upgrades, I would much prefer them charge for full version upgrades, and use that income to get make a product that is:
fully developed
well tested and bulletproof
well documented
not problematic to use with the more popular 3d apps
and released on time for both platforms
I don’t get the impression that 3.5 was developed under a beta test the same scale as the one 3.0 was. If it was, they would have been showing off all the work by the testers, highlighting the new features, just like they did prior to 3.0. We have an entire forum devoted to showing of 3.0 beta work. Not only that, but just after the 3.5 release, notable 3.0 beta testers were posting on the Q&A forum with issues, as if it were the first time they were exposed to the software.
The fact is, 3.5 is a public Beta, which, I think, most people would be perfectly fine with, if it had been billed as such. If it had been, people still would have gotten their new toy to play with, but would have had expectations more in line with the state of 3.5 as it is now.
I suppose they could always be the first one to do that. No brand new 3d application release that I am aware of has met all of those points simultaneously. No existing high end application is ā€œbulletproofā€ either, even after years of refinement. Let alone a cutting edge application that everyone else is playing catchup with, and defining the development frontier.
I see this notion voiced from time to time around new releases, the problem is, it makes the assumption that simply charging more money means they can make a better product, presumably by simply throwing more people at it. This runs contrary to what the brains behind Zbrush have always said. Zbrush is kind of an arcane stew that lets it do the kinds of things it can do that no other application can do on the same kind of hardware Zbrush can. There is a finite pool of special minds who understand it, and it is not just a matter of pulling bodies off the street. Pixolator has always said that throwing bodies at it would be counter productive. They expand as they are able to.
So in the end, you have to consider, that the reason they dont charge for updates, is because they don’t think they can do the things you suggest…it is always going to be a work in progress, and always going to have unforeseen problems. So they do they only fair thing that they can for their customers. Nobody has lost anything with the new update…it doesnt overwrite 3.1, or remove any of the working functionality people are used to. They have only gained new tools and new functionality that work to varying degrees.
Since theres no guarantee that charging more money for updates would result in a better product (certainly hasn’t worked for Autodesk), I think most people say they wish Pixo would charge for updates simply so they could complain with more justification, as people are wont to do when they dont get everything in the world as fast as they want it. Because in the big picture, over the years of its development, Pixologic customers have gained their money’s worth, many, many times over any other company.
ā€œThe fact is, 3.5 is a public Beta, which, I think, most people would be perfectly fine with, if it had been billed as such.ā€
I think this is where many people are semi-put off with this release. We have things at work like lazy brush constantly crashing every hour or two and this crazy appending of sub tools that is totally throwing the scale/centers off whack etc. I figured that since it was a 3.5 release that it would be rock solid since it was building on 3.1 as a point release but it’s more like 4.0 beta really. Loads of kinks that need sorting and missing functionality such as all the plugins. (Which Pixologic was kind enough to mention ahead of time would not be ready).
As for the rest of your post I couldn’t agree more Scott. I bought Zbrush back at v2 and Pixologic has consistently raised the bar with each new release. There are bugs and kinks that need to get worked out but overall my license of zbrush has made massive returns on investment and paid for itself numerous times over.
I am using version 3.2 with the latest version of the TransPose Master plugin for the Mac. Everytime I hit the TposeMesh button I get this ā€œThe selected mesh has not been saved - Please save mesh and try againā€
This happens on all models including DemoSoldier. It had been working at some point maybe before I updated to 3.2??
Update: I’m an idiot. Apparently if I save the model then try again it works. I guess I should have just followed the instructions…lol :o
Thanks for shaing:
  1. Make sure that the original model with SubTools is in edit mode
  2. Click on the TPose>SubT button and choose the Load File from Disk option
  3. Navigate to where you stored the mesh and press ok
I’ve been trying to transpose quite a heavy poly model 12 mil poly al together with subtools. Soms subtools still have acceptable low subdiv possible, others have had their lower subdivs deleted.
The converting to 1 mesh to do the transposing works nicely, transposing itself on that mesh also, but then when I click the button in transpose master to apply the transposed model onto the real model and the subtools, it starts working, some subtools appear/disappear and then it hangs , I let zbrush try for an hour, but it didn’t seem to do anything anymore and clicking on Zbrush, gave the standard win 7 , application is hanging, what do you want to do … close , wait for program , …
Because I thought it was still because of some meshes that were too high poly, I decimated all the subtools that were high poly and tried it again, but still Zbrushed hanged. I’ll try some more tomorrow :<
It’s a really cool tool when it works, but sometimes it’s hard to pinpoint why zbrush crashes or starts hanging.
There’s an issue that can occur with heavy meshes. This will be fixed in the next version.
Is there a way to avoid parts of the object not able to rotate with the rest of the body even though it’s not masked.
example : http://img405.imageshack.us/img405/3511/orktranspose.jpg
the bottom of the axe remains fixed and does not rotate with the rest, if I move the transpose line more to the other side before I rotate, a part of a hand gets fixed. If I put the transpose line lower, top of the head remains fixed.
