Pixologic Release: 3D Print Exporter
Hi everyone,
I just want to know if someone have problems with this version of 3d Print Exporter.
I can’t make it works, i used the 3.1 version wich works fine for me, but now
this one seems not working at all, it makes me 1Ko files.
If you have a trick or …let me know.
Thanking you in advance.
I am trying this too. I pres the export, and it creates a tiny file, very quickly. when I try to load it into VisCam View, it says no model loaded. Is this plugin working in R3?
I have tried the trial version of ZBrush with the 3d Print exporter but could not get it to work. Anyone had any luck with decimation master and print export ?
They look like really useful tools.
Is it possible to get an answer to this question? Or perhaps I should start a thread in the troubleshooting bit. That’s what I’ll do.
Hi every one ! I got the same Problems as Mask, Gordon Robb and niborreeb , only export a 1k file , not working !!
I need help !!! :frowning:
Hehe, good luck.
All I can suggest go to the Support Center and raise a ticket. The more of us that do that they more likely we’ll get it fixed I guess…
Just some info regarding the big question I see being asked over & over…
“Where can I print my models for really cheap?”
Here’s the best answer I’ve found…
YOUR OWN HOME!
You can build a 3d printer from scratch, using open source designs from the internet for less than $1,000. True story, no bull. Here’s a link…
http://wiki.makerbot.com/printing-videos
I’m seriously thinking about spending the money & making my own printer. The base model fo Makerbot costs about $750 to build while the deluxe costs about $900. If you make 90 models & sell them all for $10 this thing could pay for itself.
After having a very successful run of exports, my 3d Printer Exporter stopped working. It just creates a 1 KB file with no data in it. Is there a way to fix this issue? I am running the latest version on ZBrsuh 3.5R3 PC Any suggestion would be greatly welcome.
I invite you downloading again 3D Print Exporter on the Download Center and replace your current one. This bug should be fixed :slight_smile:
Before updating, please, remove the existing 3Dprint exporter plugin (the .zsc and the datafolder)
Thank you Totyo !! It work now !! Thanks !
Thanks Totyo, It works like a charm. :D:+1:
