the question is how you use the fog for get this result
very neat work. are you using custom alphas for the details?
would you mind posting a video on how you did this?
very nice image…cheers…
<link rel="“File-List”" href=“file:///F:%5CDOCUME%7E1%5CALEX%7E1.4F0%5CLOCALS%7E1%5CTemp%5Cmsohtml1%5C01%5Cclip_filelist.xml”><!–[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]–><!–[if gte mso 9]><xml> <w:LatentStyles DefLockedState=“false” LatentStyleCount=“156”> </w:LatentStyles> </xml><![endif]–><style> <!-- /* Style Definitions / p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:“Times New Roman”; mso-fareast-font-family:“Times New Roman”;} @page Section1 {size:595.3pt 841.9pt; margin:2.0cm 42.5pt 2.0cm 3.0cm; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> </style><!–[if gte mso 10]> <style> / Style Definitions */ table.MsoNormalTable {mso-style-name:“Обычная таблица”; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:“Times New Roman”; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]–> Thank you all for your kind replies.<o></o>
Sorry my little English.<o></o>
<o></o>
Tobbeo: Yes. I save time. Time renders in ZBrush is 3 min.<o></o>
kilik128: Yes. The render is only ZBrush and the subsequent updating in CS.<o></o>
Sarakawa: Displacements.<o></o>
AA-ron: apply own workings out<o></o>
Amazing work, dude! Wow, the scale of it!!
Would you mind sharing a bit about your process?
EX: what did your base mesh look like before adding detail?
How did you add the detail? was it with alphas or sculpting or both?
What is your texturing process? polypainting or image projection?
Also if you care to share any of your post production work flow that would be nice to see as well.
EX: a before and after photoshop treatment.
Great work, interested in learning how you achieve it.
…Opera!
I copy this frenchy pilou.
I can’t even discribe the sound I made when I opened this thread. It’s fikkin’ awesome!
Has a cool Giger feel to it.
Awesome!
