New z-brusher
Hi all
I just bought Z-brush today. Could you suggest som modeling tutorials to start me.
Have tried to do the cat - but the pallettes i a slight different than the tutorial - guess its an older version.
sally :confused:
I aked the same when I bought zbrush a couple of weeks ago…O)
check out the quick links on top of this site
there are tons of tutorials…
Hi Krystalmoon, and Welcome to ZBrush Central!
Try this tutorial:
Space Monkey Tutorial
And as Dragonlady said, take a look through the tutorials that can be found through QuickLinks.
We hope to see you post some of your images here soon!
-ZuZu :slight_smile:
Also, you’ll find some great interactive tutorials in the ZScripts that come with ZBrush. Just open your ZScript palette and load a script from it. It defaults to your ZScripts folder, which has several subfolders of tutorial scripts. The most comprehensive is the Picnic Basket, but the others are more in-depth for each particular feature.
Welcome!
Welcome to ZBrush and ZBrush Central, KrystalMoon.
I would follow the advice of the previous posts - check the Quick Links and watch all of the ZScript Tutorials that come with the program.
Look for the ZScript palette and click load, then look in the Zscripts folder for the tutorials and other examples.
Good luck and happy brushing!
KitchenDon
