justlearning,
Apologies for the delay in replying. I’ve not updated this yet and it won’t work as it is in 3.1. If I have a moment over this weekend I’ll take a look at it.
Cheers,
justlearning,
Cheers,
OK, here is a version for ZBrush 3.1. It’s basically the same as the original version except for the addition of an adjustment slider. Different types of UV mapping can need different scaling and the slider takes care of that. For example, for AUV tiles leave the slider at 1 but for pelt mapping set it to .5. It’s also useful for when you want to work on areas that take up more or less of the UV area.
For best results read the info in the first post and use the test files (they are still good for ZBrush 3.1).
Note: If you installed a previous version of Pixol>Pixel delete the .zsc file before installing the new version.
Thanks Marcus!
Many thanks for your work Marcus - a much needed addition
Chris
Thanks!!! Super cool
Will this work in 3.5r2?
Does this plugin works with ZB Mac 3.2? any other solution for this?
Thanks,
