Hi all. I recently picked up a Surface Pro 4, mostly for use as a zBrush sketchbook. I went for the i7 with 8GB ram.
Iāve downloaded winter and disabled flicks and my performance is good but Iām having major stability problems with zBrush.
Basically, I get a crash when I perform a dynamesh operation. My standard test is to load the program and choose the dynamesh 128 ball from the Lightbox. Generally sculpt it a bit and then dynamesh it again. Most of the time the program immediately crashes. If it doesnāt then I can usually continue quite reliably performing more dynamesh without incident. But that first one kills the program about 75% of the time.
Usual error is āzbrush executable has stopped workingā with no real info.
Occasionally I get
INTERNAL ERROR .\List.cpp Line:560
Locked main mem in list-out
Object:
then a message to email pixologic.
Now, before I go ahead on that front I thought Iād see if anyone here had experienced similar and had a fix. Right now the Surface is unusable for zBrush. Which is rather less than ideal. I appreciate any info you guys might have.
Edit: Should say Surface is running a fully updated Win 10 and Iām using 64bit 4R7 P3
