Lookin good! I like the old guy and the ogre-thing, but the back sculpt is definitely my favourite. Its really really nice work
update!!
I use shave to render the hair,but some problems make me crazy…google google until i found out solution…
amazing works
cherrypig… the hair looks great…! I look forward to seeing it on the textured head! would you mind sharing the problem and solution you found?
Would be handy for anyone else trying to do hair… like myself!
Finally, I get my fur rendered out today. I will try my best to write the tutorial about rendering fur soon.
](javascript:zb_insimg(‘179463’,‘zzzzzzzzzzzzxxxxxxx.jpg’,1,0))
have a rest,and take a shower.
i will compisit them later
Nice work! I tend to avoid dynamic hair cause it’s so frustrating and always comes out wrong for me
Hence Looking forward to your fur rendering guide, would appreciate that, thanks!
I cant waiting for this tutorial ! thanks a lot and Congratulations !
Good work, it’s great to overcome obstacles. Looking forward to your tutorial!
Cheers,
Keridan
You use Shave for the hair eh? Even better, is what I use too, looking forward to the solution since you googled so much.
I figured one thing out that you can use hair primitives and rasterizer or rapid hair preset settings in mental ray for Shave hair, but with that the rest of the model looks crap, so u must comp them but I didnt find a good way to use this with my lights and as a pass which sets shadow on the underlying model i.e. shadow pass and hair pass etc.
I would appreciate a tutorial as well if you got a good workflow for this.
Also have you ever tried to make long stylized hair with curves in Shave? If so and you managed to make them well I would also appreciate a workflow on that coz mine always suck no matter what I try, especially hair intersections for different hair segment curves. Anyway maybe I’m asking too much, but thanks either way
but i found new problems with render hair.
i want render separate pass for fur&hair ,but the hair primitives can’t render out the passes…
i just figure out how I can render out this passes
sorry,im late.
this is my gird hair.
](javascript:zb_insimg(‘179757’,‘jk.jpg’,1,0))
I participated a contest in cgtalk. this is my w.i.p…
http://forums.cgsociety.org/showthread.php?f=208&t=853778
Great designs. Your understanding for forms and poses makes your work more out standing. Keep going!
thank you for reply.I will update when i finished uv. keep focus ,thank you
that’s only things to block my way!how can I render output the shave shadow pass with mr,but I find new solution ,this time I decide to use it,
this is shave render test VOL I
](javascript:zb_insimg(‘184557’,‘feffffffff.jpg’,1,0))
if I solution this problem.I will promise what said at last month.
](javascript:zb_insimg(‘185645’,‘neil.jpg’,1,0))
the contest was finished on this day…but still have some problems composit fur in photoshop.
Hi, i work in 3Ds MAX, but the hair module is still shave and hir cut.
Things to remember:
S&H shadows works better with spot lights.
Check the premultiplication of your output hair layer in order to avoid weird halos at the compositing stage.
In the link below you will see a cartoon monkey, i rendered the hair using this technique.
cheers,
mirrored.
really nice model! and with the hair it looks so cool.
nice done! now it only needs a cool pose and render.
edit: just looked through your thread. it has only awesome stunning pieces! i admire your talent. keep it up
small_orange_diamond
thank you for you post!!i will try it again aggggggggggain.
