Import color/texture to Autodesk Maya
I´m very new at using 3D-Modelling Software and i have a question now.
I´v sculpted a model in Sculptris and added a red “W” to the chest of my figure for testing, if it is possible to import the texture to Maya. But when I import the model to maya, there ist no color on it.
Can someone help me?
Marie
if you painted your model in Paint Mode, then you need to export your model FROM Paint Mode. You need to also export your Texture map. Then you’ll need to manually import your texture for your model. I don’t know Maya, but in most apps there’s a Material channel. Make sure your Texture image finds it’s way there …
thanks, but i already solved the problem. I had not seen the “show advanced tools” button. But with this tools it was quite easy.
Marie
