I know, I had to make one to delete it so it wasn’t that… mope…
:lol: Consumption of fingernails is not good. It was working, what changed? Not the atomic structure of matter.
Did you install anything or update anything before it stopped working? I assume you searched your computer for *.cfg and deleted any named as in earlier post, “Windows this is: Users\Public\Documents\ZBrushData\ZStartup\ConfigFiles”
I know, and they taste like fingernail…
ick!
It happened WHILE I was in ZBrush I think, its hard to say that for sure because I wasn’t using 2.5D or the sculpting tools at the time, but all hell broke lose, I decided that restarting ZBrush was a good idea (like maybe it was crashing or something) and quit without saving, when I started up again the simple brush didn’t work and neither did the standard brush and on top of that thee canvas was messed up.
In order (just a few moments ago) to find out if I had accidentally saved a startup document I tried that feature out, I had not accidentally done that as there was no file there yesterday and so therefore nothing to delete. Basically in order to find out what the file would be I had to create one… so much for that.
I have not installed anything for quite a while and the only thing that has updated is virus definitions which is sort of unrelated I should think and happens just about every day.|
Startup Document…:rolleyes:
Not sure if your PC is set to auto update, maybe it’s a service pack. :qu: Can you get to add/remove programs, show updates and see if there is anything there about when your machine died?
THAT was great thinking, but believe it or not didn’t work.
It loaded fine but I still have the same problems. I think the only thing to change is you seem to have an all black background…
This is a new computer, the old one is the one that died, so I dont think its that.
hmmmmm…
I need to look into installing from scratch I think…
Im so tired that this is scary, I need to sleep before I try that.
Or make coffee…
…and then some more coffee
Sigh, yes the background was black and 4096 X 3???..4(1024x768)
GRIN!
That isn’t a problem, and thank you for sending it to me.
I should make a document like that when I get this fixed…
Ok…
I have no idea what happened but its working now and I do not know why.
Thank you all for the help! Im so baffled it’s ridiculous.
None of what I tried worked but suddenly its ok, what is the possible cause of that?!?!?!
