the stage
the stage
This one was based on Nevermind’s cover from Nirvana and Mr. Krabs from SpongeBob SquarePants
So epic. What Vray material is this?
Frigid thanks! which render did you mean?
Another project. Thiago and Luka
awesome and cOOL
sherkhan thanks!
I started with ZSpheres to create a basemesh for my model. From there, I subdivided as needed as I crafted the basic shapes, and used the Move brush to adjust the silhouette. After that, I started to add the basic shapes of the
eyes and mouth.
To sculpt the cloth, I created a mask on the basemesh, and then extracted a new mesh from it. I started by making the collar using the Dam_Standard brush to mark where I want to create the collar, and then used the ClayBuildUp brush
to fill it.
As I did with the collar, I used the Dam_Standard brush to define where I wanted to create the blouse, and used ClayBuildUp to fill it. After that, I used the Move brush to get the silhouette that I wanted.
rom the cloth mesh, I masked and then extracted a new mesh to create the tie. Using the Move brush and Inflate brushes, I got the shape that I wanted. To create the symbol of Gryffindor,
I downloaded a black and white image from the internet and imported that image into an Alpha. Then, using DragRect, I created a mask based on that image and used the Inflate brush to sculpt the shape of the symbol.
For the hair, I started with a sphere around the head, and used the CurveLineTube brush to draw a line where I wanted to create the strand. After that I used the Move brush to create the basic shape of the strand. Then I used DynaMesh to merge it with the hair.
Timelapse - Hair
//youtu.be/watch?v=3InbHALfYe4
The clay material was pretty simple to create. I played with BerconNoise Map (a free plug-in) to get some variation on bump map, and I also added a VRayDirt map to get some variation on the Diffuse.
I change the light in every scene I make. In this case I used just one light on the top. For the camera, I like to work like real life, so for this piece, I thought a telephoto lens worked best, so I just put 200mm as the focal length (which is basically what I changed from default setup)
Joey Ramone
Daily Sketch (Concept by Patione)
Lisa Simpson (This image is part of “Simpsons: 25th Anniversary Tribute” )
Daily Sketch - Rafinha Bastos (and Walmor) - (Concept by Bruno Jacob)
Daily Sketch - Kim Jong-un (Concept by Jason Seiler)
Anatomy study (Skull)
Parabéns, excelente trabalho!
Congratulations!
Very good model and render. Gratz!
gerbilho, firebat Thanks!
Daily Sketch
I love how you rendered the skin on this latest one so that it looks like a middle ground between realistic skin and clay.
