Definitely getting some weird behaviour with this… I can send meshes to ZB but can’t send anything to XSI… what is up with that?
Wich version of Sofimage and XGoz are you using?one click Xgoz is compatible with versions up to 2012,beyond that its not working perfectly.
XSI 7.01 and it was working fine for me…
It works fine with ZB4r3 and XSI 2013. Just follow the steps on page 3
Anyone have it work on R4 ??? I can’t make it run
Hello guys,
I’m still using XGOZ because I like it more than the official GoZ for Softimage (GoZ for Softimage is doing trange things on my machine… for instance changing size and other other things…).
How ever for my uses I found out that XGOZ fits more my needs. I just installed it for ZBrush 4R5 and Softimage 2012SP1.
It works well, butt every time when I import or export stuff with the xgoz-plugin i receive following message window:
Script: XGoZ_Plugin.txt
ERROR:7476
IN: [IPress, 7476]
What does this mean, and how can I fix that message?
Thanks for any help!
Below two screenshots when importing and exporting meshes via xgoz
Hi guys,
am also using XGOZ still becouse it fits my work much better than official GoZ, but same as the giotto i have the error message plus i have to manualy enter full path to the project in ActiveXsiProject.dat. Can anyone give some hints how to solve this problem.
Thanks
Someone get any idea about Uv please when i go in zbrush is change my uv it’s work’s when i import in obj
Anyone still using this ? I just can’t make it run with Zbrush 48
