I Jester,
I’m Steve Jubinville, character Artist and Certified Zbrush Instructor.
Thank’s a lot you your XSI Addon, working really well!
After couple of try, I see couple of mistake in your installation explanation.
I re-write the exemple in english and French!I hope your are ok with that!
I don’t know what you thing about that but is maybe the time to links you with Xavier Durant, the guy who create GoZ. He will help you to integrate GoZ XSI in Zbrush and help you to eliminate the import/Export. It was betther if is doing automaticly. So if you’re interesting send me your email adress and I will make you in contact with him!
Thank’s Again!
Steve Jubinville
How to install GoZ for Softimage:
installation:
English:
Drag and drop GoSoftimageLiteAddon.xsiaddon onto Softimage viewport or do File/add-on/Install…
Set File/Preferences/Custom/GoSoftLiteSettings and point the Zbrush Folder C:\Program Files (x86)\Pixologic\ZBrush 4.0.
Open C:\Users\yourUserName\Autodesk\Softimage_2011\Addons\GoSoftimageLiteAddon.
Copy folder GoSoftimageLiteAddon and paste in C:\Program Files (x86)\Pixologic\ZBrush 4.0\ZStartup\ZPlugs.
Really important, Rename GoSoftimageLiteAddon with GoSoftLiteData.
Open the folder GoSoftLiteData/zcs/ and paste folder GoSoftLite.zsc in C:\Program Files (x86)\Pixologic\ZBrush 4.0\ZStartup\ZPlugs.
For the sake of safety restart both application.
Everything working fine now.
In Zbrush, in the Tool panel, you will see under the export option GoSoftimage Lite: GoSoftimageExp and GoSoftimageImp.
In Softimage, File/ GoSoftLiteExport and GoSoftLiteImport you will see the option under the Save As.
installation:
Français:
Glisser GoSoftimageLiteAddon.xsiaddon dans le viewport de Softimage ou faire File/add-on/Install…
Aller maintenant dans File/Preferences/Custom/GoSoftLiteSettings et pointer le folder Zbrush dans C:\Program Files (x86)\Pixologic\ZBrush 4.0.
Ouvrer C:\Users\VotreUserName\Autodesk\Softimage_2011\Addons\GoSoftimageLiteAddon.
Copier tout le dossier GoSoftimageLiteAddon et le coller dans C:\Program Files (x86)\Pixologic\ZBrush 4.0\ZStartup\ZPlugs.
Tres important, Renommer le GoSoftimageLiteAddon par GoSoftLiteData.
Ouvrer le dossier GoSoftLiteData/zcs/ et copier le document GoSoftLite.zsc dans C:\Program Files (x86)\Pixologic\ZBrush 4.0\ZStartup\ZPlugs
Fermer et ouvrer les applications a nouveau.
Tout est maintenant en place et fonctionne.
Dans Zbrush, dans le Tool panel vous verrai en dessous de Export l’onglet GoSoftimage Lite: GoSoftimageExp et GoSoftimageImp.
Dans Softimage, File/ GoSoftLiteExport et GoSoftLiteImport se trouve en dessous du Save As.
