Thanks a lot guys, very much appreciated
Santis - thanks for the info and link, i’ll see what i can do with Camtasia
Sleepy - Thanks a lot man, really glad it was helpfull!
Jaggudada - Thanks a lot man, glad it helps you
sure, i’ll show my MODO
pipeline for you, i’m too busy right now, but very soon i’ll make a explanation
with some screen grabs for you,
Just a brief explanation for you beffore i make the explanation:
1- Export the maps
2- Open your model in MODO (the one with the same UV’s used to bake the maps)
3- go to the “Render Settings” page in MODO
4- Click on the “Item” corresponding to your model
5- Click on the “Add layer” in the right top of the page “Render Settings”
6- Choose image map
7- Click on Load image
8- Browse and load any map you whant (diffuse, normal, bumb…etc)
9- It will be set as diffuse as standard, you can see it in the right column
10- To change the tipe of map, place the mouse cursor over the right column
where it says diffuse, right click with the mouse,
11- Just when you right click it, it will open a dialog with many options for you
to choose including (duffuse, normal, bumb, tranparecy… etc)
12 choose the one corresponding with your map and it should work just fine
PS- Sometimes in MODO the correct map doesn’t work fine (it is a bug)
if it happens, just delete the map from the shader three and load it again, it will work,
Let me know if it helped you !
Soon i’ll post the explanation with the screen grabs
Cheers!!!
