Hello Everyone. I was searching for MEL Scripts that involved Zbrush and Maya and I found this one:
zayaTools
by FiendishVegan
I believe this is the best MEL Script for creating displacement maps in under 1 minute. I’ve tested it on two models and I had great results.
It’s still unfinished. You can’t work with normal maps, but FiendishVegan is working on it. There are some artifacts when working with subdiv, but I think it was because of my 1024 displacement map. However a 1024 displacement map works great with polygons.
The Workflow:
After opening Maya, you can do two things,
option 1: import the model, then open the script; or
option 2: open the script and start from there. I prefer this one.
Alpha Depth Factor, I start with 1.
After that, hit create maps, and then your done.
If you did the second option, your model may look rough. I use this script to solve that problem:
migNormalTools
Under Maya’s Default, click on Average. This will smooth the polygons.
