In Deformation>Smart Resym button
First you have to make a mask of the good part of your mesh (half the body for example, an then click on this button).
should i do this masking before i transpose it, or after
Bascically it will make a symetry. So before or after the transpose, I would say it only depends of what you want to have as final results… a perfect symetry or not…
I meant, i transposed my sculpt, and then I want to continue symmetry sculpting on the arms, so I should mask one side, and hit deform\smart resym, so now even though my right arm is up and left arm is swung back, I can still work on one of the arms and symmetry sculpting will apply to the other on the same areas correct??? :rolleyes:
oh nope
The smart resym is just to correct something and make a symetry based on the good part of the model… Like a mirror if you prefer.
Once you’ve transposed the model, well the symetry can’t work… because it’s based on the coordonates of the mouse… It doesn’t take the body part or area you’re working on, into consideration…
so im doomed HAHAHA :evil:
