Female form speed sculpt (Nudity)
Quick update. Here is a render in Modo with slight sss and 1 area light.
…modelling work!!!
Hi Tez,
really, really, really good!! :+1:
I almost like better the first render - Zbrush…probably nicer shades, but is just a personal opnion!
How you did the lashes?? I’m trying to figure out how to add them to my poor model…:confused:
Any suggestion or hint would be really appreciated!
Luca (camillo)
Em, did a small edit, since I like it.
Keep up the good work!
Regards,
Aleksander
[attach=73409]NEW (19).jpg[/attach]
camillo, Thankyou. As this is only a quick test texture to have a small break from the sculpting, I used Zproject to add eye lashes, eyes and eye brows. I then hand painted the rest in zbrush.
Now when I do the finnal texture I will not have them painted on, but make them out of a small plane that is the size of the eye lash length and width. Il then paint a texture black and white to use as a trans map. All black areas of the texture will be invisable. Onto the last render, I had a few versions rendered out and this one looks more realistic to real life, athough the zbrush preview version has a nice viberant glow. When I rendered the one in Modo she had more colour but I drained it out of her a little. Im getting some nice results from my other renders in Modo and when Im finnaly happy I will bake and add dynamic hair in Carrara pro 6. Her finnal pose im not sure on yet, but am looking forward to finnishing her off to start all over again :smiley:
AleksanderA, Thanks, apreciate that, check back soon there will be some full body renders from modo soon. Im hoping to get a Wacom pen soon, this should make things more natural and faster.
A update to this model. I spent a little bit of time on it today. This mesh got edited adding new hands, and cleaning up the topology in Hexagon.
[attach=75358]9.4.01 TORSO bbody strip.jpg[/attach]
[attach=75359]9.4.01 arm under.jpg[/attach]
i wouldnt push her off my bed ! even though i prefer real women:lol: eyes are also an plus! :lol: :lol:
Feet and ankles… Need a little work, but overall I like it. :slight_smile: :smiley:
I notice how she shares some features of angelina jolie.
I did a few minor tweaks and aded some texture, mite work on this some more.:smiley:
very nice work. :+1: :slight_smile:
Hi Tez,
very good progress so far!! I like the texture too! :+1:
luca
great model so far. Love the shape and pose test! :smiley:
keep it up
Hey thanks for all your comments. Im working on a pose right now. The pose is in its early stages, so havent done any sculpting as of yet.
Here is a quick W.I.P pose. As usual render is in Modo from which im making a skin shader as well. No textures in render yet.
Here is a update on this pose and render.
Tez,
Great thread!! Not sure how I missed it but glad I got to check it out. Love the progression of the female form and interesting to see how your going about posing the model. I love the shadow really helps accentuate the form!!! Not sure what type of finished scene your striving for but will be interesting to see. With the hardwood floor and pose… just need some perspiration then would remind me of a dancer/gymnast finishing up a hard practice session(though not sure why she’d be naked, though I’m not complaining).
looking good but there are alot of problems with the skinning or transposing that you are doing.
The thing that stands out horribly is the bend of the feet. Take your shoes + socks off and bend your feet in the same way…you can’t. The joint is in the wrongplace. Look at the wrist, it’s too thin at the bend. .
I think you are heading in the right direction and doing well but think you have rushed through a few stages.
The davinci pose looks odd , the rib cage looks too low, under the arms appears to angular and protrudes alot. The collarbones are at 45degrees rather than 90. The posed model looks better but there are still joint issues.
I’d drop the pose, drop a few sub d’s and develop the form/ flow of muscles and bones etc. Actually, drop the texture/colour as well and concentrate on the form as you’ll see it better without colour. THink marble statues.
http://images.google.co.uk/images?q=greek+classical+sculpture&gbv=2&svnum=10&hl=en&imgsz=
Once you have nailed this, retexture/colour and then return to the pose. And then after posing you can subtly adjust the muscles for that pose.
Might just be the render angles and a few wines but looks wrong in places.
check out loomis books
http://fineart.sk/index.php?s=112&cat=12
Hope this helps.
Keep up the good work. Definatly heading in the right direction but think you’ve hit a couple of speed bumps on route :wink:
El-d
el-d, your totaly correct. I have done things ass back to front, this was because im learning Modo so speeded off ahead to set up a scene, before she was totaly finnished.
Once I settle with Modo I will stop doing so many test and do things in the correct order, my bad lol. Your again corect about the bone deformation and rotation joints. Today is here I go back and refine her form more anatomicly.
Now I have the sceneset up reasonably I can just drop her in at any stage during her refininf sculpt.
Thanks for the crits, please cme back and crit my next stage.:+1:
AngleJ, thanks for your comments, means alot to me to get feedback, keeps the interest alive in the project with such kind comments. 95% of my other work post didnt even get a reply or at least a rating.
The standard on these forums are getting higher and higher, hard to keep up in order to give the viewer enougth interest to reply.
tez,
I think the biggest problem this model has is its lack of proportion. It looks like you have focused on the parts individually rather than looking at it as the sum of its parts.
Meaning, go for the illusion rather than the explict details of human anatomy, i.e loosen it up a bit.:cool:
Im not seing the lack of proportion, could you please advice in more detail on this and the term, loosen it up more?
Thanks.
‘Im not seing the lack of proportion, could you please advice in more detail on this and the term, loosen it up more?’
-The shoulders look too wide and could drop down a touch.
-the hips could curve in more and in relation to the shoulders width may need to come in more.
-the naval could be raised a bit.
-with regard to ‘loosen it up’ what I mean is in my opinion the muscles aren’t taking the weight of the pose, exagerating this will help the anatomy read more clearly, of course taking it too far will throw out the balance.
-Be careful with how much the shoulder blades protrude and their angle.
-The arc of the back may also need to curve more to maintain proportion.
-Either the ears are too big and need to come forward more or the back of the head needs more volume to it.
-The neck appears to need a little more length and finally the head may need to be enlarged a bit.
I think its looking good just needs the final touches:+1:
