omg that axe is epic! great work
Thanks man…to bad the axe was a doodle and not related to the game:)
This pipe however is…trying to acheive realism for all the game props and doing some key stone assets to teach the team:)
Simply kick ass work!
Fuse box…i did it in 1 hour – modeled and textured using my new workflow. I PROMISE…a tutorial is coming soon.
I primiarily did it in Zbrush…using this new workflow i am come up with. Enjoy
Great work!
Can’t wait for the tutorial, how generous, thanks in advance.
THanks man…
again this asset was done in my zbrush club…the students ended up settling on LOTR generator…
I bit off a bit more than i could chew…i was going to do a windmill…only finished the base. And not very well…pulled out bricks on top to far etc.
You can at least see some progress on it though:)
great stuff man … really liked the Plant Pod with Corpse …
Damn man, your ****ing awesome
Pillar…actually recorded doing this thing from start to finish:)
NICE!
small_orange_diamond
It looks great! But those wire armature wiggly vines wouldn’t really do the job of holding that block together, definitely works good if you intended them to be a metaphor, if not - not as good. I don’t care much for visual effects only serving the purpose of visual effects, so don’t hold it agains’t me, for I don’t hold agains’t vfx because of vfx, but I don’t feel that kind at all
Hi man, Your work looks awesome.
I couldnt stop me from commenting this ehehe.
The pipe in particular is awesome but i would like to tell you one or two things in that work that i think could be more correct( more close to reality).
The flange of the pipe is wrong, way too thick and the bolts are way small if that was a huge flange. Also i think you atempted to represent the weldings and it looks great however from the inside when a pipe is welded the welding inside its merged with the surface of the two pipes or the pipe and acessory.
Also unless its a huge huge huge pipe or extremely thick it only takes one weldind. You can see it here: http://photo.machinestogo.net/main.php?g2_view=core.DownloadItem&g2_itemId=143&g2_serialNumber=4
A real thick pipe with just one line.Usually those weldings are done with several layers the first one being the smaller and growing inside but from the outside u see it really think and only one line or two and in the inside u see only 1 line of welding.
Just my two cents since your trying to make it realistic.( im a pipefitter) hope i explained myself welll, sorry for the english.
http://www.made-in-china.com/image/2f0j00oBJQNFGIrDcWM/Ductile-Cast-Iron-Fitting-for-Flange-Pipe.jpg
Some fantastic sculpts in this thread Nick; especially like the game level sketching stuff too.
Was going to pick up the eat3d pillar tutorial, looking at you results, I thin k I will!
Great work, look forward to more
Azurea: Yah…thanks for the crit. You are totally right. I neglected alot of reality when doing the pipe. I was testing out my new process of texturing at the same time i am modeling and it got away from me;)
RawSunlight: NOOOOO don’t buy the tutorial unless you want to use mudbox. I used the tutorial as inspiration but did it TOTALLY different. All in zbrush and way faster:)
Here is an update to the pillar:) As well as todays fightclub for my class. The students settled on Kungfu Chainsaw…here was my interpertation.
nother doodle from my zbrush class…the genre that won was scifi and the object was monkey
so here it is;)
](javascript:zb_insimg(‘154789’,‘scifimonkeyhead1.jpg’,1,0))
GET A TUTORIAL UP!!
Your work is brilliant and exactally how im wanting to be at in a year or so!
done 99% in zbrush…alot of projection master:) render in zbrush color correction and compositing in photoshop.
Man this is amazing work! Way to go! If you could record your next project in zbrush for us that would be awesome help and inspiration!
