Can't Access Spacing Options in Brush Modifiers
Hey guys,
It’s probably a noob question but i can’t access my spacing options in any brush i pick (Stroke>Modifiers>Spacing) Most options are grayed out in this section.
Any ideas why?
thank you in advance!
-Eugene
Context sensitive, if it doesn’t apply, you probably don’t have the right thing selected.
hmm…i had a clay brush selected, but i tried standard and a bunch more with no luck of ever getting these options. What steps do i need to take to unlock spacing setting in your stroke?
http://docs.pixologic.com/reference-guide/stroke/modifiers/
I looked at the documentation before posting. They only have description of the functions there… In the screenshot Directional is turned on and i am guessing that is what enabled the options below. However, these options, including Directional are grayed out for me and that was my question. What i see is that with all brushes i tried ReplayLast is enabled instead, everything else is disabled and i can’t figure out how to enable them.
You must have missed some bits then. What are you trying to do?
I am trying to sculpt a welding seem between too pipes. I was planning to use a clay brush with a round alpha and a dots stroke. that get me 80% there, but i want the stroke to be spread apart a bit more so that when you brush you dont get a solid line but rather a number of circles that overlap each other, thats where spacing options comes in, however it’s grayed out. and i don’t understand why, or how to enable it.
Somewhere in the IMM thread is a brush you can use. I looked a bit for it. Maybe someone knows the link.
cool. where can i find that thread? whats IMM?
iNSERT MULTI MESH.
http://www.zbrushcentral.com/showthread.php?170167-Insert-Multi-Mesh-Repository&highlight=IMM+REPOSITORY
Unfortunately, using a IMM brush doesn’t really answer the question. I want to create my own brushes that do very specific things and I am unable to get the Spacing attribute of Modifiers in the Stroke menu. I’ve switched through all of the available stroke types and it doesn’t appear become active in any of them.
In the documentation here:
http://docs.pixologic.com/user-guide/3d-modeling/sculpting/sculpting-brushes/strokes/
it discusses changing the spacing on the Freehand stroke, so I don’t think it’s a “wrong stroke selected” sort of thing.
Any ideas anyone?
Hello, I have exactly the same question. I’m trying to access the “spacing” modifier (to make patterns on clothing), but it doesn’t seem to ever be available. I also looking in the “brush” panel for something similar but no luck.
I remember being able to use the “spacing” modifier with all the regular brushes in previous zbrush versions so this is a bit frustrating.
http://docs.pixologic.com/user-guide/3d-modeling/sculpting/sculpting-brushes/strokes/ I follow what you guys are saying.
With an alpha and the standard brush with smooth stroke, if you select Roll and adjust the roll Dist slider to maybe 4 you should see results. However maybe not the ones you want. Spacing settings and adjustment appear to take a while to adjust as needed.
hey guys , i have this problem too,
i test almost every brush but i cant access brush stroke spacing ,
but when i use 2d brushes , it activate again ,
maybe its only for 2d brushes , isnt it?
Yeah this is really strange. I would like to edit the same functions. The documentation even toutes it like a feature but then it is greyed out and you can’t access it! That doesn’t make any sense to me.
I’m really needing this. How can I edit the spacing on a brush? thanks.
Ive run into this same problem. You should be able to go to the stroke menu, turn on lazy mouse and use the lazy step slider to increase the distance between the dots. For some reason the modifiers are always grayed out for me also so this is the way i do it.
So has anyone figured out this problem? It’s frustrating as heck. And yes, we know about the lazy mouse workaround, the draw slower workaround, and the mouse average workaround. I just want to adjust the spacing for my brushes.
Arrrggghhh. I haven’t checked every brush, but of all those I’ve tried it is greyed out. There has got to be a simple answer to this…
same here. Can’t access it, and it’s been 5 months or so I’ve been using Zbrush. what the heck is happening here?
Is this for zbrush or sculptris?I am confused. Because this is the sculptris forum.
