<iframe src=“http://p3d.in/e/idGzU/spin” frameborder=“0” allowtransparency=“true” width=“100%” height=“400px”></iframe>
I think I found out that P3D uses the normal map as a bump and not a correct tangent space calculation.
This causes artifacts on the UV seams.
The only reason I think this is the case is because it does the exact same thing in Maya if I don’t select tangent space, I could be wrong though. You can clearly see where I cut the UV on the knee, the shoulder, around the collar bone, the elbow, the hips, every seam is visible.
