20 min Model in Cut & Paste HK 3D
Thank you Light, jakeychan
:smiley:
<object width=“640” height=“505”><param name=“movie” value=“http://www.youtube.com/v/Elpu6t6Ir5w&hl=en&fs=1&rel=0”></param><param name=“allowFullScreen” value=“true”></param><param name=“allowscriptaccess” value=“always”></param><embed src=“http://www.youtube.com/v/Elpu6t6Ir5w&hl=en&fs=1&rel=0” type=“application/x-shockwave-flash” allowscriptaccess=“always” allowfullscreen=“true” width=“640” height=“505”></embed></object>
<object width=“640” height=“505”><param name=“movie” value=“http://www.youtube.com/v/DXWkTp6457A&hl=en&fs=1&rel=0”></param><param name=“allowFullScreen” value=“true”></param><param name=“allowscriptaccess” value=“always”></param><embed src=“http://www.youtube.com/v/DXWkTp6457A&hl=en&fs=1&rel=0” type=“application/x-shockwave-flash” allowscriptaccess=“always” allowfullscreen=“true” width=“640” height=“505”></embed></object>
beautiful :sunglasses:small_orange_diamond:+1:small_orange_diamond:+1:small_orange_diamond:+1:
Thank you ! tokio :smiley:
hey , very nice work man
can u give me an idea abut ur work flow for making the details of the horns ? thanks
Really nice sculpt here. I think the horns on “day 08” are simply amazing!
If I can offer some advice / crit? I think the tail would look a lot better, more anatomically correct if it started from her sacrum bone, that would place it just above the crack of her arse. At the moment I think it looks wrong coming from her spine. Just a suggestion, overall I like it. :smiley:
3d70mohamedaly
:smiley: About the horns , I just spent a day ,turn and turn around to do the details of the horns,I was used standard brush to do it .
DigitalDreamer
Thanks for your advice, I know it ! I will try to fix it ! :smiley:
If you go back the video you will see the I can’t pull the tail Z sphere in the right position . Sorry I try to forget it !! :stuck_out_tongue:
Thank you !!
I just Fix the tail !! :smiley:
Finally I put it in maya !! :smiley:
Dude this is cool! The skin looks stretched and burned… but its sort of hidden under the red paint… Just my 2 cents - Awesome model!
Cool stuff in there. Liked yours 20 min models a lot. The red candle stick women :slight_smile:
Good continuation for your present model.
SixxPixels
Thanks !! A human became a devil . :smiley:
Daaims
Thanks !! :smiley:
Really nice job on moving the tail! I think it looks much better now. :smiley: Can you tell me how you moved it to maya, decimation master or displacement maps? Also is this poly painted or texture? cheers mate.
:smiley: Thanks ! DigitalDreamer
Yes ! I used Polypaint - AUV - 8k UV Map - decimation master make the main body from 10,619,392 down to 2,097,152 polygon . Than export to maya,
Very big file very slowly , I can’t open this file in another computer,Only i7
x4 CPU 8Gb ram … Display is slowly but render time is ok !!!
I try to make uv in uv layout, but crash many time in level 1 of this model .So I give up and use AUV and Polypaint. It look ok right now !! :smiley:
Thanks mate. I look forward to your next models. :smiley:
<object width=“640” height=“385”><param name=“movie” value=“http://www.youtube.com/v/h5GukCampj4&hl=en&fs=1&rel=0”></param><param name=“allowFullScreen” value=“true”></param><param name=“allowscriptaccess” value=“always”></param><embed src=“http://www.youtube.com/v/h5GukCampj4&hl=en&fs=1&rel=0” type=“application/x-shockwave-flash” allowscriptaccess=“always” allowfullscreen=“true” width=“640” height=“385”></embed></object>
DigitalDreamer ,
Thanks ! Keep on going !!! :smiley:
:smiley:
Beautiful renders, so nice to see a rendered turntable. Good to see your work rendered up so beautifully :wink:
Very nice indeed…:smiley:
