Hi Bill
No sorry In this site, It’s for personal use ! You must buy it for a professional using !
Pilou
Hi Aztec
You have not given the good member, It’s Upham and not Cameyo who give the link of your beautiful pull over texture
Pilou
Thanks for the tutorial Aztec¡¡¡
Congratulations friend¡¡
Andreseloy
In the texture panel in the reference pic. Whats the grd for next to colorize? Also wonderfully done. how do you get such a high definition image.ive been using texture master , but i cant get that "real’ look/
Pilou- u r right am sorry,I truly apologize. SSorry upham.
Andre- Gracias amigo siempre puedo contar contigo… Thx a lot!
JUSTNPROUD- I didn’t use texture master, u just get the texture and get your tool, click on your texture u want to aply, then…
under the texture panel choose the mode it will best fit your tool and also arrange the H and V repeat to make it look like there is more in one
About the “GRD” definition: The gradient colors button displays the colors of a colorized mesh with softened edges.
Hope this helps
oh one important thing is the material hope Cameyo put some in there, I would really enjoy that script… here is the material I used to make it look as if clothing. ropa.zip hope it works
Hi all,
i have a wip to test …
The image show the interface and four texture examples.
Download:
ZFabric3.zip
Some info:
The script draws horizontal and vertical lines…
You can choose colors and number of lines.
If a color switch is OFF then that color is skipped, but the relative number of lines will be counted.
Press the “Default” button before drawing !!
Sorry for poor explnation…but i must go out with my daughter.
Please test it and post result.
Ideas and suggestion are well accepted…
See you later…
cameyo
(Just a Cameyo’s texture apply on some spheres 3D
Hi Cameyo
Just 3 suggestions
A function who copy in one pass all the colors selected from vertical to the horizontal for have a symetry color texture
A function random for each color in the squares
And maybe the cross Cursor who choose color (when you press it)from texture to the palette(or canvas)when you release it (I don’t know if it’s possible
(now we are oblige to chosse on the palette and goback : I Am some lazzy
Have funny scripting!
Pilou
Ps And a last one
Why not the possibility to put in each square a texture or a piece of “surface’s canvas” grabbed?
(of course is not the same “line building” but I think that should be not difficult to realize
Fractal isn’t it ?
Pss Maybe a bug When you put the number “zero” = 0 in all square it’s seems that the process don’t stop ! A false test ?
so numbers >=1
Thanks Cameyo for yet another powerfull and
very useful script. Maybe you could write
some plugins for upcoming Z2 someday!
Aztec…soljA, That was a great methode to
make clothes, thanks a lot!
Thanks Cameyo:
- reset colors option
- have script select tool and size
Hi all,
you can do better textures…
Try again.
I have developed a new version:
- Add Random Colors
- Add Reset Colors
- Add Swap Colors
- remove the Frenchy bug
Download:
ZFabric5.zip
Future enhancements: - add apply material function
- add palette color creation
- add help and demos
- add save and restore colors and parameters(after Z2…)
Tip:
after the creation of a texture try to paint different material on canvas to obtain marvelous result.
cameyo
p.s i’ll explain better this scripton monday
Hi Cameyo
I see that my suggestions are already made Bravo !
One more
You copy all colors Vertical to Horizontal ok !
But not the Numbers ! Is it possible ?
(yes two buttons more
Have fun scripting!
Pilou
cameyo,
your scripting rocks this will surely come in handy,thanks
Hi all,
a new version:
- add two Palettes
- add resize canvas to pattern dimension
- add copy repetition values
Download:
ZFabric8.zip
I have seen few textures from users…maybe this little tutorial will helps.
The scripts write horiz and vert lines on the canvas.
You can choose colors and number of repetition lines.
The lines are one pixel width. You can change Stroke->Spacing to vary from continue to dotted line.
Example:
- Load script and press the “Default” button to set the standard drawing parameters.
- Press vertical “Random” to create random palette color
- Write the following Repeat Value for vertical palette: 2-4-4-2-4-4-2-4
- Press “VPAINT”
- Now Prees “VCol->HCol” button to copy colors from vertical palette vertical to horizontal palette.
- Write the following Repeat Value for horizontal palette: 2-2-2-2-2-2-2-2
- Toggle settings: H1=ON, H2=OFF, H3=ON, H4=OFF, H5=ON, H6=OFF, H7=ON, H8=OFF
- Create new layer (you can erase the layer if you don’t like textures :))
- Press “HPAINT”
- Now Press MATERIAL button and select a material…
- … if you don’t like the material selected…press “X” (the shortcut of “Material” button) and select another material.
More, the textures created are seamless and the script works with any canvas dimension.
I think this is a powerful texture creator…but i’d like to see your works.
Please, try it and post result.
cameyo
p.s. maybe this version had some bugs…work on the night…
Hi Cameyo
The “help” of Hcopy is false (repetition of the same word)
Suggestion : A button for an automatic grabb of the entiere Canvas ? (easy)
(for make Alpha or texture)
Have happy continue scripting!
Pilou
Hi Pilou,
i had more rensponse before add zscript…
Maybe it’s not so good as i was thinking…
But i wish only a 121 from users.
Thank you
cameyo
Hi Cameyo
No, No It’s a good idea !
But now all people are waiting the next release of Zb2 !
It’s the “stase” before the “extasy”
Pilou
Cameyo do what you feel, dont guide by the user response. I post many images here because i enjoy working with ZB and few people reply or see my post (i appreciated very much) but i dont stop to post or to work with ZB.
Is easy to see that some user dont want or dont like what you do (they reply other post at the same time say nothing to your post).
Just do what comes from your heart not from ego.
Keep on friend¡¡¡
Andreseloy
ps:your script (all) are very helpful and has been an inspiration source to other zscript programmer too¡ I want to learn script, i suggest you to make an special topic (excuse my english) about learning and making script, i have reading in ZB2 that the new version allow plugin, it will be an interesting window to learn and there you have a very important function too.
(excuse me by my english i dont feel confortable when i speak in coloquial way).
Thank you, Andreseloy,
i’m not guided from user response…you can see this from all my posts (from 2001). What amaze me is the fact i have already told: before adding zscript there was much more audience…when the script is on-line…they grabbed only. It’s not a problem for me, but it’s so.
I like a lot your images, but…i post few times on your works.
cameyo
Thats right friend¡¡¡
Keep on¡¡
Andreseloy
