Hello, please ask a question, similar to what code is used to achieve a blank interval here? Thanks, hope to get your help!
hi @zhouyoushuang please edit the title of the thread with relevant information about your request.
about your request , I’d never tested myself, and I am not sure it will work like you want it
but just as test I would have try to create a button which is disable that you, and you [IHide], well I might just remove the interface item and move all items after it .Then if it doesn’t works like the way I suggested, consider that you can’t to define the position on your items, ZBrush do it at the script startup and stack every item from the bottom to the top.
Hope it helps!
Nicolas
