I cant make the full person what am i doing wrong, any other settings i should be using with. Thanks Curt.
Have you watched the tutorials that came with 1.51 3D??? Especially the intro to ZSpheres etc??? If not then you need to do so. Also download the pdf file here Quicklinks for version 1.51
Also, make sure your draw size is set to “1” when working on your ZSphere object.
let me shorten this up for ya.
bring out the z sphere and go into edit mode or hit the letter T on your keyboard.
draw size 1
now put your curser on the z sphere and go over it again you will see a second sphere on top because you adding one which you could be so called making a leg so add just a few then in the TRANSFORM ( MOVE ) which you will need to activate you can now pull the legs out.
keep a eye on the TRANSFORM pallete thats the main deal.
the white sphere are the pivot points.
go to the default.txt and load the tut on this and look at the short cut commans on how to add sphere or piviot points or delete them ect ect
