late, but here are my kudos:
kudoskudoskudoskudos!
thank you, Peter!
- juandel
thank you, Peter!
El pix : you can try create plane in second layer, set transparency, drop in texture master ,sculpt/scale this plane so everithing is on right place, set transparency off and pick… MAybe it will work, try using edit/move a lot…
2nd question : its color bump on material, you can see the model picture in tutorial…
: El_pix, Juandel, DeeVee, Griff, Upham, Southern,StoneCutter " thanx a lot for zour encouraging comments…
Man tanks alot. this is exactly the kind of information I was looking for ! That anatomy site is awesome too. tanks !
Very artful,
I am just envying.
I would be proud if I did such a masterpiece.
Anatoly.
Thank you for showing how you did this.
Great result!
Paul
